Originally Posted by driller
I have the Steeda underdrive crank pulley, a smaller alternator pulley and the Meziere electric water pump.
The crank pulley helps out down low, the smaller alternator pulley gets the power output of the alternator at idle back to normal and the Meziere electric water pump frees up top end HP. ![]() |
Just get the crank balancer/pulley only from ASP and NOT the 3 piece.
This car is too electrical dependent and the 3 piece sets always eat alternators and slow the water pump down so much that you will see a rise in coolant temp. |
Pulleys work on the 4.6 DOHC, up to 10rwhp but you risk breaking your oil pump gears.
Jelsoft Enterprises Limited.
