Originally Posted by nofinga911
ok thanks guys....but excactly which set is for an 04 aviator?
Originally Posted by MarkVIII93
Its a 4.6 isnt it? 99-01 cobra coils should work.
that will fit the aviator? it says 4 valve...and the aviator is a v8...do you have an aol sn...would be much easier if ou dont mind...thanks
No AOL or IM for me.
The 4V coils will interchange. The 2v and 3V will not as they are angled. The 4V's are a "stright" design. 32-valve (4V) Modular V8's are: 97-97 Mark VIII 99-04 Cobra 01-04 Mach I 98-02 Continental 03-04 Marauder 03-06 Aviator These models will interchage. It's essentially the same ignition setup. 4V is what you need. 00-05 Navigator |
ok so i purchased the ones from the ebay link above...now should i have my dealership service install them or will it void the warrenty? and also has anyone heard of irotors .. rotor company because i want to upgrade my brakes but i am not sure who else has any apllications for my truck
You should be able to do it yourself, no problems. It shouldn't void the warranty- and if the dealer gives you any sh!t, tell em' that the coils they put in weren't any help, so you had to take matters into your own more competent hands.
Just follow the instructions, and ask questions here if you get stuck... |
Originally Posted by Dominus
Absolutely.
which spark plugs should I get?? Which are the best lol......and also i just got the ignition coils but should i have gotten a coilpack with them??
Since you'll be running these coils and a custom tune, I'd go with one step colder thank stock. I think Autolite 103 plugs will do. You may also want to install a 180 thermostat. With the colder plugs, coils, and t-stat, you should have yourself a pretty mean machine
oh yeah, im gonna ask the mechanic at service if he can install my coils...will he know to reverse the polarity?
Originally Posted by 98LSC32V
You can get the Autolites at almost any auto store, the Autolite 103's are made for your car and they are 1 step colder than stock. You have to pick either platinum or copper. Copper is a better conducter but doesn't last as long.
sounds good....anyone know if brakes made for a ford explorer would fit on the lincoln aviator? I cant find a big brake upgrade for my avi....and i really want brembos
See the link I posted in your other thread.
and misfiring and i attempted to install the packs myself today but i really need some help...i dont know how to reverse the polarity...or how to access my spark plugs...im not sure which ones go where...and all that other stuff...i really want to do it myself just to learn how to do it because i like to do these types of things on my own...so maybe you guys can help me...hope so...thankss oh yea and i cant find the autolight 103's anyywhere so i guess ill order them off the net..
i went to pick up my car today and they refused to install my coil packs because it will void the warrenty...they told me the truck is riding fine and the coils do not need to be changed..but all they did was run a diognostics test...didnt even go under the hood because the screws for my engine cover were untouched...but anyway my cars still riding like
![]() ![]() ![]() and misfiring |
...misfiring...not getting any power unless i fully gun it for a few seconds...everytime this happens...its usually fixed by me replacing an ignition coil...but obviously there is more to it then that....someone pleasse help me it really is driving me crazyyy...my car sounds and drives like
its horrible!!
Jelsoft Enterprises Limited.
