Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Do Gen2 ballasts fit Gen1 HID Lights?
Posted by: Calabrio
I need to purchase a driver's side headlight ballast. Can I use the ballast from a '97 Mark VIII or do I need to find one only from a '96?
Posted by: evillally
The ballasts are the same; but you may have to swap wiring connectors. I think the 97=98 ones have rounded connectors as opposed to square connectors.
Posted by: Calabrio
I don't have a '96 ballast, just everything else from a '96.
So, it sounds like hardwiring it is the only option?
Posted by: Frat-man-du
Make a connector for both ends - dont hard wire.
Posted by: Calabrio
Quote:
And how do I obtain the ends? I don't have a broken '96 ballast.
Quote:
I'm sure someone around here does. Start a wanted thread for a broken Gen-I ballast...
Posted by: Calabrio
...too bad we can't edit old posts or thread titles...
WANTED: BROKEN '96 BALLASTS!!!!
PM ME.
Posted by: Calabrio
Upon inspection I've found that the prior owner cut the ballast wire. So, I have both sides of the plug, and a few inches of wire to work with.
Posted by: seanklsc
Hey man its OK to hard wire them if you're in a jam, don't go too crazy trying to find a spare plug. Just make sure you cut, splice, and solder/heatshrink them real good. I did it for both my HID bulbs.
Posted by: poniesviii
I'd hard wire them anyways. Better than mickeying a f'n connector together.
Besides, your sh!t's already hard wired from your factory low beam wires into your ballast. What's another one make of a difference eh.
p.s. .. when you hard wire make sure you have a quality solder and correct size shrinkwrap. These headlights are very fussy about a FULL connection and NO moisture in my experience.
