ty air guns and mine broke. so now i have to screw the nuts back on, and all its doing is getting to a part where there is tension on the threads and then the ball joint just spins when im tryin to screw it on, or off. so i have half threaded nuts that wont go on anymore, or off. wtf do i do. the sway bar linkage i dont have room for channel locks, and the lower ball joint will eventually run out of room for channel locks, and there isnt realy any room for them to began with. wtf do i do? this job is pissin me the f off.
Originally Posted by 4.6powa
you can use a c clamp, or big vise grips and get it in the taper as tight as you can. use a lot of lube. what i did, was since i took out the whole controll arm and everything, i spun the rusty threads on a wire wheel on a bench grinder, to clean them up. it made it so much easier.
Originally Posted by MonsterMark
I think it is time for you to buy a Hyundai with a warranty.
Originally Posted by Calabrio
By the way- MrWilson would like to remind you that it's the car the low mileage Mark VIII that's the lemon.
yall need to go f uck yourselves. I ask for help and all you can do is mock me. you need to grow the hell up.
Originally Posted by mespock
Now guys be nice to poor Mr. Wilson... he's trying to keep his Mark running..
Is this the same one you are selling? |
i found out the hard way and, i already said how i did it. i was taking the balljoint off and the nut was really rusted to the joint, and a pita to turn... as i am unscrewing the nut... (being the bright guy i am) i didnt want to mess up the threads when dislodging it from its taper so i decided to hit the joint down with the nut still part way on. as it dropped my heart sank realizing what a stupid thing i just did, since there was no way to stop the joint from turning. thats where a c-clamp came in and a prybar... i also have now found my balljoint fork which would have been the proper way to do it...
just thought i would share my stupidity... |
Originally Posted by 94m5
everyone that was born knowing everying please take a flying leap out of the 95 floor. 62 years on this planet and still learning and trying to help those in need. if you don't have a pickle fork try using flat chisles to remove the old joint use pentatrating oil kroil or pb blaster the 2 best. even wd will held. also use 2 hammers one held to the opposite side you are hitting on the control arm. not the ball joint. sometimes they are a son of a llllllllll . to put the new one on use a 6 in c clamp and a socket to let the thread come thru the control arm. if using a hammer to lossen up the old one take the castaled nut off and turn it over on the threads to save it old racer trick. take care jd
Its nice to know some people still have respect for their fellow human beings.
Mr. Wilson, don't get your panties in a uproar. With all the trial and tribulations you go thru, and all the start and stop projects we've seen, taking a few pokes at you is all in jest. Have a little humor. After all, you cetainly entertain us enough. Time for you to have some fun too and appreciate the good-natured ribbing.
lol, Andy, I can see where you are comming from about the "making fun" part, but monstermark was just messin around with ya, nothin more. I notice my dad is back to using MY account. I'm gonna have to have a little talk with him.
Mike |
Jelsoft Enterprises Limited.
