STEP #16: Spray the inside of the transmission case with brake cleaner spray to remove the ATF fluid from your work area. Install the valve body in the reverse order as it was removed. Carefully thread two of the longer 8mm bolts into the opposite ends of the main controls, to hold it in place. Re-install the remaining 23 bolts that retain the valve body. Torque the bolts to 90 in.-lbs. Hook up the electrical connections to the various sensors. Here is the check list; TCC (Torque converter clutch) solenoid, Shift solenoids, EPC solenoid, and black plastic tab (7H141). Be careful not to incorrectly hook up the solenoids to the wiring harness or transmission damage could occur. See the CPD drawing below for details. The following shows you the torque sequence for the main control bolts. |
ing post in it, jackass... i forgot youre so much cooler than everybody else... why dont you go soke up your glory on another board if you have nothing nice to say to anybody
Originally Posted by seanklsc
This thread is so sad..
Originally Posted by 1993_M75
Maybe you should just buy a new pre-modded valve body:
http://www.factorytechtransmissions....WPROD&ProdID=6 |
Originally Posted by MediumD
$225! Plus $100 if they don't get a core. Thats a bit on the expensive side IMO...
Jelsoft Enterprises Limited.
