Originally Posted by Sergmark
Bryan,
Sounds similar to the old days when the covers had breathers ![]() |
Originally Posted by Dominus
So what exactly are we talking about here? Basic open vents? Vacuum pumps?
You should install a vacuum regulator from somebody like Moroso or Goza in the cam cover. Automatically regulates the crankcase vacuum. Nothing more, nothing less.
DO you have a catch can system to prevent accumulation of crankcase oil? |
Originally Posted by driller
Any more word on these?
Any more word on these? :roll eyes:
Originally Posted by 97quadcam
Have you considered using a vacuum control valve...like the ones that control the egr. You may be able to hook one up using a pot off the throttle...like the tps to have it introduce atmosphere at idle and part throttle and close off at higher throttle to allow for maximum vacuum at upper rpm's...where the engine needs it the most. I don't remember exactly what signal does what for that type of valve...but it should be easy to figure out. Then you'd have your "controlled" vacuum leak that you need to top this system off.
Justin ![]() |
Jelsoft Enterprises Limited.
