Originally Posted by JoshMcMadMac
There are a lot of variables. Your weight is one. The strength of the compressor is another. Small leaks (which are inevitable) are another. Driving conditions are another. There are things to consider with the system. If the compressor is rather loud, it may be getting tired. If the car does not level, this is signs of a decent leak or weak compressor. The major concern to have is the air suspension light. As long as it is off you are in relatively good shape. To answer your question, the compressor should not run for more than 90 seconds after starting the car and shutting the door. Just be careful not to rule out other tell-tale conditions.
Originally Posted by surfaaron
It seems to have to run for short bursts after I have driven for a short time. That is what makes me wonder if I have leaks. The pump is loud enough to hear from in side the car but does not seem to be to loud. The light has not come on since I replaced the O rings.
Jelsoft Enterprises Limited.
