Originally Posted by oilburner101
hi i have posted before with problems i had with putting a 2001 mustang tranny in my 1993 mark viii. now the tranny is works great when u shift manually but once its in drive sometimes it will rev like it can't find what gear to go to. having the overdrive button on and off doesn't seem to change anything. i would think it is something with the mlps but its brand new. i am wondering if there is anything else besides the neutral safety switch that would do such a thing. also note that my tachometer rpm gauge does not work i had it apart thinking it was the back face sticking it but that doesn't change anything. could this effect the electronics on the transmission in deciding what gear to be in. thanks
Originally Posted by Staffamerica74
I have his car currently and drove it tonight. Its doing the same thing as before but now if you are parked and go from park to drive you have to rev it to get it to engage into gear. Once in gear it runs and drives good in first and 2nd. Put it into 3rd and it sometimes will go and other times it will act like its in neutral. 4th gear it wont even try to go into. When going from park to reverse it immediately goes into gear. I found a tsb on this though and it says.
Known problem....water in MLP.....check and replace... ISSUE: Some vehicles may exhibit a shift concern and/or an engagement concern due to water intrusion into the MLP/TR sensor and vehicle harness. There may also be a number of different DTC's along with those concerns. ACTION: Replace the MLP/TR sensor and vehicle harness connector if signs of water penetration is evident. Refer to the following procedure for service details. SERVICE PROCEDURE 1. Verify the customer concern. 2. Perform normal On-Board Diagnostics. 3. Inspect the MLP/TR sensor for signs of water contamination. 4. If water penetration is present and DTC's have been set, replace the MLP/TR sensor and the vehicle harness connector with the TR Sensor Service Kit (F5AZ-7A247-A). I am beginning to believe that this is not a trans problem as much as an electrical problem. It did the same exact thing with the old transmission as it is doing with the new one. The new one only has 17,000 miles on it. Now if only I had my service manual and knew what a TR/MLP sensor is. |
thats been done its been switched back and repinned, the mlps is brand new for a 93 im not sure if he aligned it correctly he said he did.
this is the link i followed to repinn the harness.......http://www.tccoa.com/articles/tranny...n/page16.shtml
Jelsoft Enterprises Limited.
