Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Thunderbird SC rear sway bar
Posted by: Calabrio
I pulled the rear sway bar from a '90 Thunderbird SuperCoupe (SC) the other day. I remembered reading somewhere that this part was superior to the Mark VIII rear bar because:
1. It had a slightly larger diameter
2. It was solid
3. It was an easy swap
4. It was only $20, with the end links at the junk yard. (In case anyone suggests an adco bar)
Was this information accurate, should I bother installing it.
My original sway bar is o.k. though I did notice a tiny rust hole on it while changing the rear diff fluid.
Posted by: Calabrio
I think I read that the rear on the 90 SC was a 1.1" and solid.
What's the size of the stock hollow rear sway on the Mark VIII?
Posted by: Calabrio
I just pulled the sway bar.
WOW. What a difference in weight.
Posted by: Calabrio
...did I need to replace the end links, or can I reused the Mark VIII end links.
I did- and it seems to have installed fine. I have the SC endlinks just in case, they are a little different.
Posted by: driller
So... you want a heavier one??? LOL
Funny, only because I know guys that lust after the Mark VIII bar because it's lighter than the stock MN12 bar.
Posted by: Calabrio
No, I didn't desire a heavier one, I wanted a larger diameter one to reduce the understeer.
I guess for a drag racing application I might want to shave the extra 4lbs, but if that were a concerned I'd also remove the tools from the trunk too. I'm more interested in economic improvements to the handling.
Posted by: evillally
I think it's 7/8. Or is that the Mark VII size?
Posted by: Calabrio
There might have been a subtle improvement, I detected a faint touch of oversteer, which I'd been missing.
I'm a little worried that I should have used the T-bird end links, but everything bolted up good and looked good after the first test ride.
You should have used the endlinks...
Posted by: driller
Are the ends of the bar near level when the suspension is loaded?
Posted by: Calabrio
Additional question-
What other parts are worth lifting off of that SC?
I mentioned the seats in another thread, but having to recover them ruins the economy of that. Though, I did really like them.
The rear diff would be a 3.27 with trac-loc, could I just remove the entire pumpkin and swap it with my 3.07 open?
-is this worth it despite the addition weight of the iron T-bird rear?
Is there anything else on this car that would be worth putting on the Mark.
Posted by: Calabrio
O.K.
Better questions:
1. Are there any other cars with the IRS, 8.8, with the 3.07 or 3.27 rear, aluminum, and trac-loc?
2. How much will it cost to make my 3.07 trac-loc? Do I need to change everything inside it, or can I just buy a trac-loc assembly?
And lastly- is there anything else on the SC I should pick up?
The 1999 Mustang Cobra (3.27).
Rebuild with locker? Going price is betweeen $250-350, parts & labor.
