Originally Posted by 94mark8
can you install a new amp with stock wiring?
Originally Posted by rmac694203
Well if you want the stock speakers to work correctly you have to use the stock amp. The amp has all the crossovers internally. They say that hooking an aftermarket stereo to your stock amp will eventually burn the amp up, but it can be done. I just used a 4 channel amp to run all new speakers. Sounds good too.
Jelsoft Enterprises Limited.
