Originally Posted by MrWilson
You cant put gears in the 97 till you swap out the metric muffler bearings.
Originally Posted by MediumD
The lowest priced gears (and IRS 28spl. trac lok, which is a must) would come out of a U Pull It type junkyard... If the gears are in good shape with usual wear you can use them, rebuild the trac lok.
4.10s aren't the only option. 3.73s are available. I prefer 3.73s, I don't want to be limited to only 175mph
Originally Posted by ONEBADMK8
The cheapest set up for the 8.8 comes from Summit Racing. Summits Ford gears are made by Ford Motorsport and are $152.95 for the 3.73's and $134.95 for the 4.10's.
The FMS Trak-Lock rebuild kit's from Summit are $40.88 which I do not reccomend because MOST of the Ford carriers you will find to rebuild come from a stick shift car which brutalize the differential pinion shaft, it wears an egg shape into the bore of the soft factory iron of the carrier case and will cause premature failure down the road. The Ford posi unit is $214.88 from Summit then you buy gears and bearings, oil etc and your set. I also can't reccomend enough the FMS carrier stud kit fom Summit at $30.88. Id like to see anyone beat Summits pricing overall. |
pip pip!
my posi doesnt have any egg shaped wear, heck it doesnt have any hard wear that i can see... |
Disassemble it completely then reinstall JUST the differential pinion shaft and then "wiggle" it while it's in the bore and you will see what I am talking about.
Jelsoft Enterprises Limited.
