Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Navigator/Aviator oem wheels fit on 00 Navi
Posted by: LB3DR
Can anyone tell me what bolt pattern does an 00 lincoln navigator has?
Is there any difference in the 2x4 and the 4x4 bolt pattern?
For the 2003+ Navigator, what bolt pattern is it?
For the 2003+ Aviator, what bolt pattern is it and what size of rims do them come with stock?
My uncle has a friend who is selling a set of 2003+ lincoln navigator or aviator oem rims with tires. The rims are 17", could they be from the aviator?
Because I saw some rims like this on 2003 navigators also.
here is a pic, and let me know if it would fit on my 00 navigator.
Posted by: Lincoln Luebbe
If they are 17's they are from an Aviator. 2003 and up Aviator's only came with 17's. The Aviator has a five lug bolt pattern. 2003 and up Navi's only came with 18's. They have a 6 lug bolt pattern. I am positive of all of this. 2002 and earlier Navi's had a 5 lug bolt pattern. The wheels in the picture might be what was available on the 2002 Blackwood as well as the 2002 black monotone edition Navi, I am not sure if those were 17's or 18's though. If you want to know the exact oem bolt pattern of a Lincoln just call the local dealership. Hope this helps!
Posted by: stang99x
the 4x4 and 4x2 navi's had different studs. The 4x4 had a 14mm while the 4x2 had a 12mm stud. And he's right about the 5 and 6 lug
Posted by: LB3DR
I called the dealer and they told me that the 00 have an 5x135 bolt pattern, while the 03+ aviator has a 5x114 bolt pattern.
And yes, those rims in the pictures are 17". I went to check them out today.
Also, I believe the 03+ Navi's are 6x135 or something, but for sure its a 6 lug pattern.
I really appreciate you guys helping me out.
Posted by: LB3DR
By the way, does anyone know which vehilce these rims can fit on?
Does it fit the F-150s?
