when i put my new rims on the other day i had to turn off the air suspension to jack it up...after i was done i forgot to turn it back on...as i drove to the nearest stop sign the message came on the dash and said it was disabled...i was wondering if it will damage the SUV in anyway to drive it with the air suspension disabled? it looked really cool since it appeared "slammed" on my new 20's....any help is appreciated. Thanx.
Originally Posted by asharillc
when i put my new rims on the other day i had to turn off the air suspension to jack it up...after i was done i forgot to turn it back on...as i drove to the nearest stop sign the message came on the dash and said it was disabled...i was wondering if it will damage the SUV in anyway to drive it with the air suspension disabled? it looked really cool since it appeared "slammed" on my new 20's....any help is appreciated. Thanx. |
Originally Posted by American Air-1
It won't hurt anything on an Expedition or Navigator to drive it with the switch off, but if it has a leak, you'll be scraping the ground soon. Even if you don't have a leak, you'll need to turn it back on from time to time(3 weeks or so) to let it pump back up.
So the back was slammed? If so, that would be something to look into. Each air spring in the back has its own solenoid. The solenoid acts as a gate to allow air in or out. When the switch is off, the solenoids are disabled and no air should go in or out of the air spring. If it does, you have a leak in the air springs. I would recommend doing a leak test and go from there. http://www.americanairsuspension.com/LEAK%20TESTING.htm http://www.americanairsuspension.com/ |
Jelsoft Enterprises Limited.
