Originally Posted by TheRebel
Also the wipers should wipe once automatically when you start the car if you have them in auto mode before the key is in the ignition. They should do this even if there is no water on the windshield. It lets you know you have your wipers in auto mode.
Originally Posted by ToddG
This is correct, however I don't know if it will tell you anything about how the rain-sensing system is working. In other words, the one wipe that happens when you switch to auto mode is not necessarily indicative of correct system operation. I think the only way to test it is to do what Jim suggested: get in front of the car with the garden hose and hose her down!
I know, sorry for useless info, I just wanted him to make sure the system was atleast coming on.
Originally Posted by LINLIN
Thanks for all the suggestions.....
I'll have to check for the red light and try spraying some water to test it. Even before this problem it never did the single wiper thing when starting the car. I allways wondered why, but the system seemed to work OK otherwise. Sometimes I wished it was more sensitive to a light drizzle but other than that it was fine.... |
Originally Posted by StinkinLinkinLS01
Let me know what they fix and how much it costs...my sensor has never worked. Thanks.
Jelsoft Enterprises Limited.
