Or, any ideas?
Originally Posted by hannibal
I just picked up my new (new to me anyways....) 02 LS V8 today. During my picking it over with a fine tooth comb, I noticed that three of the wheels are damaged where the small center caps are. It looks almost like the wheel has corroded underneath the chrome and is making the chrome crack. One of the wheels is so bad that the center cap is actually missing. Anyone ever seen this before? I'm going to see about getting them redone tomorrow, although I can't imagine it being cheap. Anyone selling some of these cheap??
Or, any ideas? |
Originally Posted by OldRelayer
I don't have an LS but I suspect it is the same problem I had with my Mark Viii chrome wheels. They got so bad they wouldn't even hold air and needed to be replaced. I went for the factory OEM Aluminum wheels which are much better, although they certainly are not as sharp as the Chrome. It is a pity you didn't notice this before you bought the car, maybe they would have helped more in getting you an alternative wheel. Mine is a 1998, you would think by 2002, Ford would have fixed this annoying and expensive problem.
You may get lucky and find a less expensive alternative, but it takes a lot of looking. It took me 2 years to find decently priced wheels. You may try the Tirerack.com, they have some interesting wheels. http://www.tirerack.com/upgrade_garage/WheelSearch.jsp?&autoMake=Lincoln&autoModel=LS+V8& autoYear=2002&autoModClar= |
Originally Posted by grdur3
i have an 02 same problem mine has 10350 miles on i asked they said the problem was was something to do with the process and they wouldn't stand behind it????????????????? Getting ready to go aftermarket and save these for winter...Good luck
Jelsoft Enterprises Limited.
