Hi, I just bought a new 99 Navi and i'm not sure if the air ride works. The truck seems to sag in the back when parked. When I turn the suspension switch to off it dosn't seem to make any difference. Any ideas?
Posted by: enskanker
Theres almost certainly more sophisticated ways, but if you put any offsetting
amount of weight in the truck the system should level itself. Try putting some weight in the back and see if the compressor kicks in to level. Thats how my '98 worked and my '03 is the same.
Posted by: pokeeto2
Before ever starting the truck, sit inside as you do add weight to the truck, leave the door open, just turn the switch on but don't crank or start the truck, (Ya no when you hear the chime and the lights in the Spedo come on.) After a few seconds of turning the switch, you should hear or feal the compessor kick in. It always works on Continental, Town Cars, Marks.
The way ya specify what the truck does, id say try doing this in the moarning after the truck had some shuteye.
Though, you should see the ( Air Ride Off or Check Air Ride light) come on if you shut the air ride switch to off. Even after a drive, the moment you get out and shut the door, you should here a click and a faint sound of air releaving which is the truck lowering back to normal level. ( Like a car with really slow hydrolics movements)
