Originally Posted by Mark VII '84
I have an "84 Mark VII that runs fine when cool but as engine warms up to normal operating temperature it will stall. When you try to start it again it will not start unless you use starting fluid. The pressure valve at the top of the throttle body if depressed shoots out fuel so I don't think it is the fuel pump. If anyone has any suggestions as to the cause of the problem I sure would appreciate it, Thanks!
Checked EGR valve and very little carbon build up inside, in fact EGR looks fairly new. Do you have any other suggestions?
Jelsoft Enterprises Limited.
