Just washed the car.Not the engine,I go to start it and it seems to idle rough for a second.If I put it in gear without hitting the gas alittle it dies.Starts right back up,If I rev it up just a little it comes back down to normal idle then drives perfect.Just a glitch from something getting damp?Something is telling me My TPS is starting to go.First time I have ever had this problem.No Codes no CEL.Any suggestions?
Posted by: Frat-man-du
Gas cap tight?
Posted by: Chaoticbastard
Just went out and checked.Yes it is
Posted by: buddylee
have you tried reseting cpu by pulling the - batrey cable .
Been a few hours,Everything is running perfect again. As long as it stays that way I am cool
Posted by: 94m5
IV'e had elevated moisture levels cause a hiccup or two. You SHOULD be fine.
