Originally Posted by paulownian
Can someone tell me if using a 3,100ohm resister to override the sensor and tell the computer that it is receiving air at an optimum temperature of 53 degrees works? If it does, why not just go to radio shack and buy a resister cheaper than what is advertised on ebay. See the web site below. Thanks,
http://cgi.ebay.com/ebaymotors/20HP-...6798 09QQrdZ1 |
Did you give up on the Jag Mina project?
Can you explain the offroad pipes and dumby senders? |
I believe when the dynoed the LS with and without cats - it was less than a 3hp increase....
IMHO - you buy it from a tuner that does lincoln LSes - don't buy it from SCT directly. If you do a search you find a couple of recommended places - I personally use Torrie form FastPartsNetwork.com - you can e-mail him at torrie@fastpartsnetwork.com like recommended in post#7
Jelsoft Enterprises Limited.
