Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
96 Black STS. might want to sell her!!!!!!
Posted by: NashBridges
OK for starters yes she still has a blowen head gasket. but other than that id say the car is an 8 to 9 out of 10. Has 150,000mi. on it Black on Black. What do you fellow members think a car like this would be worth with this head gasket issue??
Posted by: kissedvfd
Lot of people looking at your post. Post a few pictures!
Posted by: Future
IMHO not as much as one would think, only because of that head gasket issue.
I recently turned down a 2 car deal because of blown head gaskets. They were a 94 conti and a 96 Nissan 626 both for $650.
Sure the head gaskets can be replaced for about $1000 each, but you'll never know how much water got into the heads, you'll never know if any water caused rust, and how much rust there is.
I went through the hassle of replacing a head gasket once, and I'll never do it again simply because the engine still blew. I'm only 1 person putting in my $.02, so you can expect more answers that will sway your way.
Posted by: nobodyspecial
Quote:
Same here, I recently helped my brother with a 3.8L Ford motor that blew a head gasket and I told him flat out that I could fix it (although the new bolts are outrageously priced) for not too much cash in parts, but that I could not guarantee that he did not score a bearing with the coolant running around through the oiling system. Essentially, unless I am the one that blew a gasket and knew 100% that it was only for a few moment of running before it was shut down, I would not do the repair. Seen many examples of spun bearings shortly after a head gasket repair. Whomever buys it is taking a chance, not to mention the chance of warped heads.
Posted by: scott9050
My Mustang spun a bearing shortly after the head gasket went out. I would consider the minimum of a junkyard engine replacement.
No water is getting into the engine. It just seeps a little bit of combustions into the cooling system. Its a very odd problem cuz u can drive the car normally forever!! Week even!! But as soon as you put ur foot down it will just seep a little bit of air in. And when you shut it off it will burp some coolant out of the tank.
Posted by: CpeVillStr90
The car isn't worth much. Consider this, a new Northstar is about 7 grand. With a running Northstar, the car isn't worth 7 grand.
Posted by: Future
Quote:
You can almost be posative that if you're still driving it, a head is cracked and taking in water. It doesn't have to be anything more than a hairline to screw ya.
I was able to drive my acura with a bad HG and a cracked head, but the engine was toast. Eventually you'll see her start to just stall out, and thats when you know it's over. Only thing left is a new engine or a phone call to the local junk yard for a pick-up.
Posted by: mhinchley
Quote:
Put a remanufactured engine in it for $3000, then sell it.....or keep it. Would be worth it. Book value is around $6k
http://cgi.ebay.com/ebaymotors/CADIL...mZ8048 604085
Personal Loans:Credit Cards:Montana Music:Debt Consolidation:Debt Help
