Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Light clunk/toe in change on 1-2 shift
Posted by: John Hubertz
My new 94 (100K, dealer serviced since new) runs beautifully, but I notice a very light rattle over expansion joints (from what sounds like the right rear) and when accelerating hard it is obvious that something is loose back there, the toe in changes abruptly on the 1-2 shift and the car tries to jump sideways - the harder I'm accelerating the more it happens. Feels like the toe in may be changing abruptly, once again I'm thinking it is looseness in the right rear.
Anyone have and advice on what to check and what goes bad back there?
John
Posted by: mespock
Have you changed your 1 2 accumulator?
Posted by: 1wykdmk8
Are you saying that the rear end goes sideways? If that is the case, then you may have bad hub bearings in the rear. Or, possibly the swaybar has broken, but more than likely the hub bearing is shot. If this is the case I recommend replacing both even if the other is fine.
Posted by: Frat-man-du
Check the swaybar - they are hollow on the Marks and prone to rust. Get a solid replacement from a late model Thunderbird SC.
Posted by: NYC LS8
Mine would go sideways on the 1-2 shift, too. But that's because I left out the lower spring when I did the 1-2 accumulator upgrade.
Credit Cards:Online Advertising:Car Insurance:Loans:Homeowner Loans
