Originally Posted by scott9050
Are you meaning the rod that comes through the top? It is easy to replace with the panel off, I believe going from memory that it snaps into another plastic piece in the door going to the lock mechanism. It should pop right out for replacement.
Originally Posted by chickenviii
if its just the plastic knob that broke off the top you can just unscrew it and get the know from any crappy little parts store for like a buck
Originally Posted by 67Continental
i was thinking that too - the screw is visible. not sure if i have enough left on the stalk to get a grip to unscrew it tho.
Originally Posted by rmac694203
I have to do it on mine because If I use the lock buttons on the remote or on the door panel my alarm goes off after about 30 seconds. Pushing down on the lock stalk doesn't arm the alarm.
Originally Posted by Moes8
just curious,when do you ever have to manually pull/push that know,i cant even tell you what the door lock knob on my car feels like,never touched it,like i said,just wondering.
Originally Posted by 02LSE96LSC91SE84TC
Did you change the sensor on the keylock, its different than the one on the latch. Just asking, not trying to p you off with the obvious you probably already tried. Alot of alarm sensors are negative tripped so its kinda backwards how it works sometimes.
It;s not like the alarm system is useful in any case...
Jelsoft Enterprises Limited.
