Originally Posted by Clown2theleft
I could have sworn the minimum octane rating is 91, not 93, but I've only gassed it up twice, and ran 93 once and 94 the second.
As far as everything else... Sorry. I'm not familiar enough with the car to answer, but I bet someone around here is... Best, --The Clown to the Left |
Originally Posted by ignorant prodigy
From what I've read the engine is a high compression motor so 93 octane is required.
I understand it has a single knock sensor? how effective is it in retarding the timing?
What are the main restrictions in the set up?
I Does the LS have good size manifolds/headers?
I were to add more air, how manys lb's are the injectors rated for? and how's the fuel pump hold up over time?
How much play is there is the heads of an LS.. would bigger valves and a port job be beneficial?
How's the transmission hold up to extra abuse?
Just from reading this forum I've notice that there isn't a whole lot to be done.
I did read the 12 page thread about adding the t-bird m90. It's a very clean setup from what i can tell. I'd love to see some 1/4 times when it's all said and done.
Originally Posted by Quik LS
almost zero afermarket - there just isn't alot of people will to tackle performance upgrades on the 'luxury' vechile. As the cars are changing hands to 2nd and 3rd owners - typically younger - most stuff is starting to show |
. How do you do it Quick (personly I think your a ford spy)
Originally Posted by Silver02Sport
Dam Quick beat me to it agine guess that what I get for takeing the time to spell check
. How do you do it Quick (personly I think your a ford spy) |
| Spark is normally the minimum of MBT and at the spark level at which knock begins (borderline). Running closer to MBT when the engine is borderline limited would mean running higher octane fuel - since the LS already runs on premium, so we are always teetering on knocking.... |
| The PCM. You must implement every change through a 're-flash' of the PCM code. We have come along way in the last year on the ability to do this - using the SCT XCalibrator and a tuner that understands the LS. You can purchase the software directly - but is frankly is more complicated than I can handle. |
| They are a Delphi FJ10533 injector. The LS uses an 'air assisted' injector - which means that there is a air line coming from the intake into an 'air rail' half-way up the injector to mix air into the fuel delievery. This adds better atomization to the fuel spray. |
| Changing the injectors is a challenge - since you will not likely use the 'air assisted' type when upgrade - you'll have to go through a dramatic re-tuning - running very very rich initially. (this is the point where I am at in the SC installation on my LS).... |
| A port job should add some good hp |
the pre-03 LS used a 5n55r - I believe rated for about 340hp the 03+ use a 5n55s. the trannie will be the weak link. |
91 is the minimum though I have never in my life seen anything but 87/89/93 hell I didn't even know there was such a thing as 91 octane before I got my LS but apparently it depends on your region.
I assume you know the difference between the sport and non-sport packages as well as the 99-02 and 03-06 differences
Originally Posted by SoonerLS
I know the difference between the '99 LS and the '00-'06 LS. The '00-'06 LSes actually exist...
Jelsoft Enterprises Limited.
