I have a 1988 lincoln Mark VII LSC it just started doing this several mths back and is now starting to annoy the hell out of me as it does it more and more. All i do is pull over shut the car down and restart it and it will lift back up. Now its just hissing and sitting on its ass. Just the rear suspension is doing this. The front is absolutely fine. On some days it will lift up and stay leveled all day long and then some days it will level out and then drop back to the ground. What might be the cause of this. Does anyone have any ideas and or clues and or fixes.
right now its just sitting on its ass and im not driving it cause i dont want to hit anything and bounce and ground out. It wont even lift now. It tries but then i hear the air coming back out ..could it be the sensor in the rear or what else..HELP!!!
Originally Posted by JoshMcMadMac
In the instance where you are driving and it drops, does the check suspension light come on? I would suspect the o-ring in at least one solenoid is failing.
Originally Posted by StincolnLincoln
i am seriously thinking of the conversion kit for the air ride where would i get that from.
I highly recommend fixing the issue instead of bandaiding it.
ty. maybe i will just change the rear bags to a coil i was damn near to the point i was gonna put air shocks on it and level it and leave it
Originally Posted by Black87LSC
Which is exactly why he should put coils in. The air system will only be bandaided until it $hits the bed again
hits the fan again
im telling you i cant wait to fix this then my next project will be the exhaust from the headers back i will most likely post a new thread on that to see what type of headers to get and mufflers and so on..
rear a$$ drop while driving now fixed
i think i will be ordering afull conversion kit by the end of this week. just have to find a plce to put them on at a reasonable price lol..im tired of the damn car dropping like a fat booty lady ..Thanks guys
Originally Posted by LuxurySportCoupe
...There is not a single person that can say bags are MORE reliable, IMO i trust a steel spring with ALUMINUM perches holding up a 4000lb car over a rubber pouch with PLASTIC perches filled with air, any day of the week...
Do you want "plush comfort ride" or "handling".
If you want your car to ride like a bubble and float over bumps- stick with bags. That is not for me, i want corner carving, responsive steering. There is not a single person that can say bags are MORE reliable, IMO i trust a steel spring with ALUMINUM perches holding up a 4000lb car over a rubber pouch with PLASTIC perches filled with air, any day of the week. I lost relativlely all body roll with JUST new shocks and coil springs...the mention of springs being a "bandaid kit" is total bull. HOW???? How the hell can someone say that? They use the EXACT SAME concept, the SAME setup, just replace a bag with a spring. Not only is it safer, more reliable, more durable, handling is improved. I have since completed my suspension minus subframe connectors and front poly lca bushings...i dont think i will even need the bushings, might do it anyhow. My ride is harsh and tight. OF course, i poly'd the whole damn thing out and rebuilt the suspension. But you can bet your ass that it will outhandle every single mark vii on this board that is running airsprings without subframe connectors or a full gtc performance package (gtc air springs, custom bars, panhard bar, etc) Think i'm full of crap? Drive my car, you'll see. In fact you'll probably go drop over 2k in suspension like i did the next day and never look back. Its a NIGHT and DAY difference. Stock mark vii's suspension disgust me. In fact, the mention of this topic disgusts me. The air suspension is great if its maintained, its just not for me. To each his own. This is just one persons experience and preference. |
josh..
josh.. CFH- sure you can take it around the block, i'm in south jersey btw. Stincon- LOL, i'm not fighting. I hope no one took offense to my post. Just stating experiences and opinions here, thats all. ![]() |
That's one thing I like about the maturity of the Lincoln crowd.
Originally Posted by OldSchool1
[dryWit]Yeah. That's the ticket. Those rubber products only lasted 15 to 18 years so rip them out and throw steel in it's place. And when those darn rubber radiator hoses go after only holding up 18 years, replace them too with steel. The next rubber tire that goes flat after only ten or fifteen years of use, should also be replaced with steel.[/dryWit]
This is Bags vs Springs version 435,2653,987 All five of my Mark VIIs have bags and I love the ride. My last air ride suspension repair cost $40.00 plus tax with Ford Motor Company parts. Dude has bad bags in the rear. I'd replace em properly and the car will ride another 15 to 20 years on air ride springs ... when the ![]() ![]() ![]() hits the fan again ![]() |
Jelsoft Enterprises Limited.
