canned all that air ride bs. I'm pleased and i havent looked back.|
Originally Posted by eglade
Blackout turned me on to Suspension Alternatives. They have the complete conversion kit to convert to coil spring and were the lowest price found.
Also they offer 1.5" lowering as a no cost option. |
Originally Posted by ND4SPDLSC
The front set up will swap over, but you need Maximum Motorsports' ball joint adapter. I'd even swap the steering rack if you get MM's adapter joint and mill 0.250 off the rear of the mounting bosses for more ackerman steering. You do need to weld in new spring perches for the Mark though. The air spring perches were not designed for the loads of a coil spring and have been shown to deform over time. You should do a search on www.fordvschevy.com's Lincoln section.
Jelsoft Enterprises Limited.
