Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
The well dressed garage tool box shall have;
Posted by: torquemonkey
So what should the enthusiast’s garage have to keep and maintain a modern Lincoln? As I have a Mark VIII, I recently have learned that I will need a scanner, like a Snap on MT2500 to properly install a master cylinder on the TEVES 20 brake system. So that the tool may tell the ABS pump to oscillate to bleed the air out between the pump and master cylinder itself. Are there any more Tech tidbits like that out there?
So far I have acquired:
· Digital Multi Meter for checking DCV, Continuity and Diodes.
o Cheapy Craftsman model
· Superchips Model 1725 Max Micro tuner
· Possibly pick up Snap-On MT 2500?
o For ????
· Possibly pick up Superchips new PC based tuner?
o http://www.sctflash.com/product_racer.php
o Superchips Custom Tuning - Tune with confidence
It's here! A single PCM package that gives the hardcore racer the control he has been dying to have. SCT Ford Tuning Software gives you COMPLETE control of the PCM for all your tuning needs:
· Tune like the pro's and eliminate the guess work with a system that has been field tested and proven to work.
· Built in help files, with the ability to document your changes.
· Easy to use, windows based program.
· Support for most Ford ECM's (4000+)
· Now includes the SCT Raptor, a $475 value! The best datalogger available!
· Now available in two versions! Burn your tune to a 4-position chip that plugs into the PCM or flash the computer through the diagnostic port with the PCM Flasher.
Available for most late model Fords. Options will vary
Calibration Features:
· Four Bank tuning, the ultimate control
· Firm Shifts (Automatic)
· Elimination of Speed Limiters, Torque Retards, Timing Retards
· Speedometer Correction
· Full control over the EEC
· Multiple Program Design, allows YOU to select your level of power.
· Programs designed by the experts at SCT, for YOUR vehicle.
· Optional built in TWO STEP LAUNCH LIMITER, no need to add other hardware. (5 speed only - limited support - contact us for details. All 99+ Mustangs are supported.).
Master cylinder replacement;
Have “We” as a group have a home brewed solution or is this a shop only deal?
MPAA:Homeowner Loans:Car Insurance:Loans:Adverse Credit Remortgage
