Originally Posted by Bates93Mark8
I want to put Hids in my 93 the housings and all but Im not sure what Ill need or how I need to go about doing it as far as I understand they pretty much bolt in eccept for mounting the ballasts? some info would be great thx guys?
thanks.
Originally Posted by JC1994
And I don't have relays in yet so when I turn on the high beams, the HID's {low beams} turn off . also I recommend Sylvania Silverstars for your high beams, They are SUPER bright.
Originally Posted by 94m5
JC, 30 minutes worth of work and you could keep your lows on while the highs are on. this will cut down on hot restarts which high tension ballasts Do NOT like.
It only involves one jumper wire between the 13 and 15 pins on the multi-function switch. Works like a charm, I have it done to the 94, and the 95 with no problems. |
Nah, I don't have any type of problem with it as is. BUT, I do recommend putting a set of relays in the system to lower the current draw on the main headlight switch on start up.
The ballasts draw a TON of amperage while it's heating the hids up, and wires have been known to get hot and eventually melt. It's really simple to do, and actually helps reduce light off time for the HIDs, and makes the high beams brighter. (edit..... You will still have to do the 13-15 wire jumper to keep the low beams from turning off.) |
Jelsoft Enterprises Limited.
