Originally Posted by Roadboss
I am currently having a whole packadge assembled as we speak. I can tell you that the very first thing you need is alot of money. It is impossible to do one thing and not having to do a few other things to make the whole system function properly. You have to replace or rebuild the exhaust system, the rear gears, the fuel delivery system, the heads, the block, the tranny, etc. You really should consider a mustang or something if all you want is a SC modular motor. I am retiring so this is my Gold watch, as I plan on keeping this car a loooong time. When its done I will have as much into the project as a new Mach 1, this is the choice I made, just trying to give you a heads up on real life, so you might want to consider a less costly approach to modding you ride.
Originally Posted by 95LSC32V
Actually the 96-01 Cobras have the exact same pistons and rods as the Mark VIII.
Originally Posted by 1996mark8green
i just want to know what car do i get the cruise and accel cables and what parts of intake do i need to make it work
also will the alternator bracket they give also work thanks dave going to run 6 or 8 psi and be building the other engine i have while i run this one for now , it has 115,000 never leaks or uses any fluids and is nice and strong |
Jelsoft Enterprises Limited.
