hey all ..
i have a 97 TC and the drivers window is no longer working.. this is the second time this has happened and both times the exact same thing happened i put the window down it went down about a 1/4 of the way and then it stopped it sounds like the window motor is "free wheeling" and when it stopped moving i head a loud pop or crack almost like plastic breaking i can hear the motor working but it does not move the window up and down the same thing happened about 2 yrs ago but at that time the car was under warranty so it was the dealers worry... but now i am out of warranty and want to fix this on my own... has any one else had this happen ? it seems to be a common problem .. i rarely open the drivers window as i hate wind noise and i ususally use the sun roof ... i was able to pull the window back up and it stayed there in the up posistion but now when i try the power window button it sounds like the motor is binding up i think it is the regulator but before i got tearing my beautiful interior apart i want to know what i am getting into so....
Help !!!!
any input is appreciated
thanks
towncarss
Posted by: tbsrider2000
The thread below was posted by Sixlitre a while back. My driver's side window had failed as well. I followed these step-by-step pictures and was done in about 1/2 an hour. Costs about $5.00 for parts. I have a 1992 model, but I believe this will work for '90 - '97 models...
i have a 98 TC that I purchased these parts because the rear driver's window failed, but I got hit by a dump truck and it was repaired in that settlement.
Now my 95 cobra convertable passenger front window is failing, can i use the same parts & process to fix that?
