Originally Posted by JoeyLincolnMK8
here you go buddy
http://www.lincolnvscadillac.com/tec...tors/index.htm |
Originally Posted by mark0101
This is for the gen 1 mark. I am doing my brakes from that artical but can't get passed that since I can't find any screws to remove it. Do I just pull it out.
Originally Posted by Joeychgo
Yes - the rotor itself isnt held on by any mechanical fasteners. Once you remove the calipers, it 'should' come right off. If it doesnt, try giving it a few whacks with a rubber mallet. It might be held on by a little rust or something.
did you break in the new rotors?
The following procedure is called “bedding in” your brake pads – it helps reduce brake noise and makes the pads last longer.
Originally Posted by PioneerCrazed
Front or rear? Either way, it's about the same process. The bolts are all on the backside, and the rotor isn't really held on by them. You just need to first take the caliper off, then the bracket that holds the caliper. Then the rotor should just slide off. Good luck...
Jelsoft Enterprises Limited.
