Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Continental Digital Dash Swap
Posted by: crookshanks
Is it possbile to just swap part of the dash out. I want to take the display that tells the oil and gas and switch it with another dash. One of my leds that displays the exact amount of gas died.
Posted by: MichiganTeddyBear
if your talking about the entire digital cluster.. you should be able to without problems. if your talking about just the module that displays the gas/temp/oil/bat (one on left in my 91), if your carefull, yea, you should be able to. but try to stay in same year for the parts... there may have been subtle changes from year to year I am not familiar with.
and, if you change the module, its delicate operation, you have to remove the cluster, then disassemble cluster (do DCL tune up while in there), then reassemble it
Posted by: ColorMeConti
:i
vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2009 - Created by Stefan "Xenon" Kaeser
