Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Phantom Shifter or Gremlins?
Posted by: Terrance
Lately while driving, my '94 M8 changes gears without me doing the shifting.
Now I realize this is what automatics do, but should they shift down while cruising 50-60 MPH along the highways, or just meandering along the streets at 30-40MPH.
In the past it would shift up to 4th in the first 30-40 MPH and unless I stepped on it it would stay in 4th at 14-1500 rpm at 50-55mph. Now It seems little gremlins are in there shifting down to increase rpms when I am really not in need of them. Sometimes it even feels like it is slipping instead of grabbing. I drive with rpms as low as possible for better gas milage. What would be the cause of this unnecsessary shifting, anyone know?
Posted by: JC1994
sounds like the T/C. sounds like it's slipping in and out of lock-up.
Posted by: Brozly
There's a couple threads about this, I belive it's the Transmission Lever Position Switch...(TLPS), or close, also known as Neutral Saftey Switch. Do a search to make sure I got the name right, and replacement procedures
Posted by: scott9050
Quote:
It's also knows as the MLPS and is a $25 part and an easy install.
Posted by: Brozly
Quote:
Yeah... what he said...
I was close.... I just had to change mine, most of the parts stores around here only know by neutral safty switch, I think it cost me $34.
vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2009 - Created by Stefan "Xenon" Kaeser
