Originally Posted by Brendan
I am about to try and fire up (hopefully) a 1988 Mark VII LSC that hasn't been started in a couple of years. I found the following general guide on the net. Anyone see anything problematic here? Thanks in advance for any replies. Brendan.
Welcome to the boards Brendan. The stuff you found here is good info, but not entirely necessary just to start the engine after sitting for 2 years. I'll give you my .02 worth. Drain and properly dispose of any gas in the tank, in the carburetor float bowls and also flush the fuel lines. I know this may seem like a terrible waste, but bad gas gives you nothing but trouble! (just as your mother!). If for some reason the car doesn't start, the more potential causes you have eliminated ahead of time, the faster you'll be able to find the problem and get on the road! It's tough to drain the gasolone out of the tank, short of dropping it down. Any idea how much gasoline is in it now? I would first see (with the gas gauge) how much is in there now. If only a few gallons, top it off with the same amount of new gasoline. If it is full, you'll need to siphon some of the gasoline out of the tank. Your engine does not have a carburetor, it has 8 fuel injectors. Although you could disassemble everything and drain the gasoline out, I would just start the car and let the fuel from the tank flush the injectors out. Once the engine is running, I recommend topping the tank off, installing the proper amount of gas line antifreeze, using up that tank of gas, filling it back up, and changing the fuel filter. Drain, flush and replace the coolant. I know you only put it in three months ago, but many of the newer 'coolants' have corrosion inhibitors to help protect your cooling system. These corrosion inhibitors have been eating away at the rust inside your cooling system for the past 90 days, so flushing things through could prevent a blockage and subsequent overheating the next time the mercury soars. Replace with fresh coolant. A 50/50 anti-freeze/water mix is fine. Do this after the engine has been started. No need to spend money on coolant yet. Besides, you first need to find out if the thermostat will be operating properly and find out if the water pump will start leaking. I would recommend topping it off before starting the engine. Change the engine oil. Oil that has been sitting in an engine for three months is likely to be contaminated with water and possibly acids that can cause premature bearing failure and rust inside the engine. While you are at it, now is a good time to change the oil filter too. I would do this after the engine has been started and running. Cold oil will take a very long time to drain out. Check the oil level first and top off as necessary. Charge the battery, and keep it warm until you are ready to use it. I agree with this. Better yet, just buy a new one. If the car has been left for a very long period of time unattended (more than 90 days), remove the sparkplugs and squirt some form of 'upper-cylinder lubricant' into the cylinders. This will help free any piston rings that may have become stuck. This is a good idea too. Keep in mind the engine will smoke BADLY when it is first started. Bleed the brakes and check the operation at the wheel cylinders. Make sure the Brake and Clutch master cylinders are full of brake fluid. Brake fluid can absorb water very quickly so make absolutely sure your brakes are working before tearing off down the street! If the car has sat a long time, it is recommended that you purge the system of old and possibly contaminated brake fluid. Don't forget to check the operation of the 'hand' or 'emergency' brake too! OK, make sure the brake fluid is topped off, but don't worry about flushing it out yet! Mark VII have a specific method of bleeding the brakes that requires the engine to be running for the accumulator to be full charged. Worry about this later, along with changing antifreeze. Install the warmed and fully charged battery in the car. With the spark plugs removed, turn the engine over with the key several times. The aim here is to let that oil you put into the cylinders lubricate the cylinder walls, so you don't scratch things up, and also to 'prime' the oil and fuel pumps ready for ignition. You want to continue cranking the engine until the oil pressure gauge needle moves up, or your oil pressure 'idiot' light goes out. I suppose you could do this, be prepared for a mess. I would reinstall the spark plugs, reattach the wires, and pull the coil wire off instead. Let the starter crank the engine over. The oil light may never go out (our cars do not have oil pressure gauges). Crank it about 5 times for 10 seconds, should be primed enough. Replace the spark plugs, ensuring to reattach the leads correctly. Now remove the air filter cover and liberally spray some 'engine starter fluid' like "Ez-Start" or similar, into the mouth of the carburetors.This will greatly increase the likely hood that your car will start first time and you want your engine to have the best possible chance for 'first time' ignition as you can give it. Leave the air filter cover off for now. Take the air filter out of the filter box to make sure nothing has made a nest in there. Again, our cars do not have carbs, EZ-Start can not be simply sprayed down the carb throat, although I've sprayed it down the throttle body in the past. You should not need to do this. Get behind the wheel, make sure the gears are not engaged, depress the clutch, give it a little bit of gas or choke and turn the ignition key! (Hopefully you are cheering at this point to the sound of a running car!) Reattach the coil wire and crank it up. Once the engine is started, listen for any strange noises. Don't rev the engine, rather let it 'idle' until it reaches operating temperature. Replace the air filter cover. Check there are no fluids leaking beneath the car, check the brakes work, then staying close to home, take the car on a short 30 minute run. This will loosen everything up evaporate all the moisture in the exhaust and in the engine. Once back home, check again that there are no fluids leaking beneath the car. Wash the entire car and apply a good wax. Don't forget to clean the inside. Do this early in the day to give it plenty of time to thoroughly dry before your run. |
vBulletin Copyright ©2000 - 2009,
Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2009
