to
Originally Posted by eL eS
I fixed the same problem myself a few months ago. Talk to Maxx at 5 star, copntact info is in my signature, and he can get you going on the parts.
It could be one of a few hoses that are specific to the V6. I have lots of documentation along with photos. There s another thread already going one this topic that was started recently. |
Originally Posted by Lincolnlov
eL eS,
I recall that you got a new Infinity (sweet), but didn't realize that you still have your LS. Glad you're still with us. All that hard won knowledge isn't going to waste. And, thanks for all your informative posts. Lincolnlov |
. Thanks for the kind words.
Originally Posted by tireman
Here is the most likely problem. I just went thru this routine. The code comes up lean both banks. Ok , you have a vacumn leak after the MAF. If you check everything and all is tight, then it is the PVC valve hose under the lower intake manifold. This hose is rubber and cracks and splits because of the heat. This is an obvious design flaw and i have complained to Ford about it. Others have had the same problem. The response from Ford? Sorry about that. Cost to fix $400 from dealer. $380 labor + $20 part! My LS is 2001 and would stall over and over in traffic and stall out just sitting in the garage idling. It does not get any better. This is a tough job to do yourself. Any questions just ask. Keith
Originally Posted by Quinton
My wife's 00 V6 LS was doing this exact same thing. It was a boot leak but I don't remember the part #. If you look at the plastic cover piece on top of the engine and go straight back towards the firewall you will see it sticking up. You have to buy the boot and the metal bracket it is a part of. It cost around $25. While my mechanic friend was fixing that I had him do the spark plugs, pvc valve and the 90 degree boot that connects to it. Seems to have a little more power now.
Go to Ford and you will find the part on their computer. I gave them the part # of the long metal tube that it connects to (you can see this tube running across the engine coming out towards the front) and then that part # led us to the picture of the boot and bracket. I know that's kinda vague but it really didn't have much of a name to it. LMK if that helps you. |
Originally Posted by dirtbikekid
Thanks, how long of a job would you expect this to be? I have tools and a garage, looking for a timeframe and difficulty factor. AND on top on all this......hope this is my problem should I decide to tear into it. IF they diagnose it, would it tell them that there is an airleak somewhere, or are they gonna beat around the bush?? Thanks so much!!
Jelsoft Enterprises Limited.
