on some.
Joey!!!
Originally Posted by Gothicaleigh
Someone removed the 11 second CTS?
That one is real. There are videos of it's run on the internet. Uses a supercharged Grand National engine. |
| 89 Town Car 1989 Lincoln Towncar N/A 140.0 10.000 11.000@12.00 13.000@14.00 |
Originally Posted by driller
Use "Sort By: Cars w/ proof of ET"?
Actually, most forums require some form of time slip verification and some go so far as to require witnesses of such runs along WITH the time slip. In practice most timeslip gallery postings are legit. I agree it is more useful as a tool to weigh different mods if the rif-raf if checked at the door. Jsev22, what I want to know is how you got that pig of yours to come in at 14.4 with a 2.2+ 60 foot time? I obviously don't know everything I need to know when looking at time slips. The mods list of "tranny/converter, gears, bolt-ons, heads" doesn't help much either, 'bout like mine of "Chip, Exhaust, Gears". :tongue: |
Originally Posted by Joeychgo
I really doubt it was, he said the track he ran was "his driveway" and there were a few other numbers that didnt make sense. All round numbers - no timeslip copy posted, and he never made a post on the board. Just looked too fishy. He can repost it if he likes, but it just didnt look legit in anyway and the guy hasnt been back here since he posted it.
IM not gonna delete any more though. Im not going to try and second guess. You can upload a cpoy of the timeslip so I suggest everyone add credibility by doing so. |
Originally Posted by JoshMcMadMac
Gothicaleigh, if you are refering to Jsev22, he has a time slip posted.
What type of heads do you have on it? How many miles are on the engine? Is the 270HP an estimate? |
Originally Posted by MonsterMark
Joey and I will discuss and come up with a reasonable solution. OK? I too am in favor of having a legit timeslips section, otherwise, why have it? So we will see what we can do. I sent out some emails to offending parties and am waiting for their reply. They are not very frequent here so I will give it a few days and then we will see. Deal???
Originally Posted by JSev22
Holley Systemax aluminum heads w 2.02/1.6 valves. The short block has over 113k. 270 hp is an estimate that I derived from different horsepower calculators. I will be running the car on a dyno second/third week of August to tune and verify RWHP.
If you show me some pics of your v-10 tt monster mark it's a done deal
All times should have some proof attached to remain, be it a timeslip or video...
You're just jealous 'cause my pigs faster than your pig
![]() Here is most of the details: 65mm tb, 75mm MAF, Cobra intake w/(home) ported lower, plenum spacer, 24lb injectors, 1 5/8" shortys, Holley heads, 1.7 rockers, pullies, poly mounts, Bassani X-pipe w/cats, 2 1/4" Dynomax cat-back, fenderwell C.A.I., 255 lph pump, 4.10's, Art Carr AOD w/wide ratio and 2600 non-lockup, ext. cooler, deep pan, poly bushings all riding on 95 Cobra's w/ Nitto DR's If I can get a good (<2.0 60' time) launch I should be close to if not in the 13's. Car with 1/4 tank and me weighed 3975 after my posted run. ![]() |
I've worked hard to get my 60 foot times down to where they are and can't wait for DR's!
Agreed, but realize, timeslips can be altered as well.
I wish I had a foolproof way - I cant think of one. I actually felt bad about deleting that one, because I cannot say with 100% certainity that it was bogus, but it sure looked it to me. I just hate deleting anyones posts......... How far do we take this? what if someone posts bogus info in their sig? People brag all the time -- some are fish stories -- its no different cause they put it down on the internet. |
Dam straight I'm jealous!
I've worked hard to get my 60 foot times down to where they are and can't wait for DR's!Makes me feel good that if I ever want to make my '91 LSC beater into a project, it CAN outrun the '93! That's a nice list of mods you got there. Obviously an effective combo. I still can't get over the 60 foot time vs. the 1/4 mile ET. Must be in the cams? Or is it simply a traction issue? When I have serious traction issues, I get poor 60 foot times along with poor 1/4 ET's. Good luck on your quest for 13's! ![]() |
Between the better first and second gear ratio, 4.10's and tiny converter I'm a low gear junky. I'm also running the stock cam which helps quite a bit with my low end torque. I have no problem with traction, I can't seem to make the car launch agressively enough to make good use of the DR's. When I figure out how to make it jump from the hole look out!
Thanks man, I'm hoping to get a try tomorrow night
Between the better first and second gear ratio, 4.10's and tiny converter I'm a low gear junky. I'm also running the stock cam which helps quite a bit with my low end torque. I have no problem with traction, I can't seem to make the car launch agressively enough to make good use of the DR's. When I figure out how to make it jump from the hole look out! |
Maybe add a mod to give me more hp across the board.....
Originally Posted by NYC LSC
Line lock that sumbitch!
Who says ya gotta keep the ABS?
Bringing this up again....it seems we have more 'guestimaters' and we still have the bogus times I called out before!
Originally Posted by Katshot
I can't believe you guys are sweating this issue. Posting E.T.s is SO easy to fake. I mean hell, even if someone posts a scanned slip, who's to say it's their slip? A lot of people ARE posting bogus info for sure, I've seen plenty on here but face it, guys are always gonna "color up" their performance stats just like they talk about how many girls they've been with. Guys have been doing it for decades, you'll never stop them. And as for calling timeslip data useful for comparing mods etc, that's pretty useless too. It takes VERY controlled conditions before you could even THINK of using this data as you suggest. This is one reason why all credible sources use "corrected" data. There's SO MANY variables involved.
A couple things that are probably confusing the E.T. data are the fact that some people are running 1/8 mile, and some are posting info from a G-Tech or similar instrument. These things are useful for comparative reasons when used on the same car/driver/track/ambient conditions but are hardly a true representation of an actual track time. Personally, I think posting E.T.s are fun but I don't take any of them seriously. What I take seriously is what happens if I line up next to somebody at the track or on the street. To be honest, the street's the best test because there's no time to run and get racing fuel, pull a lot of crap out of the car to lighten it up, or add/remove components, or make special tweeks just for the race. That's why I run my car at the track with a full tank of pump gas, on street tires, and nothing added or removed to give me an "edge". Yeah, I'm sure I could "play" around a little and grab an extra couple tenths or maybe even more but, in my mind it's just not true. |
Jelsoft Enterprises Limited.
