with this mod you can see your cars MPH and Coolant temp displayed on the DIC
1) Press the OFF and PASS WARMER (referred to from here as WARMER) buttons simultaneously to enter diagnostic mode.
2) Let the system read any codes it has stored. You will ultimately be presented with "PCM?". You will answer with the fan speed control button. UP = yes and DOWN = no.
3) Press DOWN until you are presented with "IPC?". On mine, it's the very next prompt. When you get to the "IPC?" prompt, press UP to enter the IPC area (Instrument Panel Cluster).
4) Press DOWN until you are presented with "IPC OVERRIDE?". Press UP to enter the override area.
5) Scroll down (with the DOWN button) until you get to Option E. Wait a second or two, and the override value will appear to the right where the TRIP ODOMETER normally reads. Yours will probably read "43". That's what mine read when I first did this.
The stock displays (for analog E/K displays) are Battery Volts, Avg Mph, Fuel Used, and Inst Mpg, for a total value of "43".
6) Use the WARMER button to increment the value of the override. In this case, we want to add Coolant Temp, so we're going to add "64" to "43", or "107". Press the WARMER button repeatedly to increment the value from "43" to "107".
If you make a mistake, you can decrement the value by pressing the COOLER button.
7) To permanently save the new value, hold the FRONT DEFROST and the A/C buttons simultaneously until the new override value flashes once.
8) You're done. Press OFF repeatedly to "back out" of the diagnostic system. You'll probably need to press OFF 5 or 6 times to get out of the deep "menu structure" you're in now.
Now, the coolant temp (in units specified) should be one "stop" along the revolving door we call the DIC. If you are in metric units, the coolant temp will read in *C. If you are in standard units, it'll read in *F.
Good luck!
BTW: the book warns against incorrectly storing an override value to the system. It said you can permanently damage the IPC by doing this. I don't know how, and have never heard of anyone doing damage to their car, but the book says the danger exists. It says if you ever make a mistake, repeatedly press OFF to completely exit the diagnostic system and start over again
