hi
my vote is for the bushing,s( i,ve woked as a wrench at times and just about every car that came in to the shop with a squeek in the front end needed the upper or lower ( or both) control arm bushings----- next choice would be the strut bushings
regards " kahuna "
back to
Originally Posted by One_Way
There are quite a few pivot points on your front suspension that could be causing this noise. I've even hear dry ball joints make this noise.
I would start where these guys have pointed you to. Find a buddy to turn the wheel so you can find the cause of the noise. If you have any friends in the medical field, a stethoscope works VERY well locating noises! Good luck and let us know how it turns out! |
Jelsoft Enterprises Limited.
