Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
still no spark
Posted by: 91lsc5spd
got a new problem now i have no spark whatsoever coil or distributor if any i deas please help thanks. I have power at the connector to the coil but then plug in to the coil and i get nothing.
Posted by: Lincolnlov
If You have access to an ohm meter check the wire from the coil to the distributor.
You may have a bad wire there. Lincolnlov
Posted by: OldSchool1
Quote:
Please expand.
When you turn the key, is the starter cranking the engine?
vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2009 - Created by Stefan "Xenon" Kaeser
