Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Is Synthetic Brake Fluid Wrong For A Mark Vii
Posted by: Mad Maxx
Wondering What The Proper Fluid Is For A Mark Vii With Abs Brakes
Is Synthetic Not Good.....the Only Dot 4 I Can Find Is Synthetic
Posted by: Awesund
Not sure, but I don't see how this can hurt anything.
Even synthetic motor oil and trans fluid are considered better, so go figure.
I need to flush my own brake system, soon. If anyone knows for certain, I'd love to hear...
Cheers!
Posted by: OldSchool1
Ask five people and you'll get five different answers.
I use Super-X Super Heavy Duty Brake Fluid in all of my Mark VIIs. It's a DOT 3 fluid so it has a higher initial boiling point and resists water absorption better than the DOT 4s.
If you're not on a budget, as FORD/LINCOLN/MERCURY for a discount on a 5 gallon drum of the OEM stuff. That's the best for our cars IMO.
Posted by: jud149
Cheers!
A general rule is to flush brake fluid every 2 years. It tends to draw moisture and that is why it needs to be changed.
Posted by: Mad Maxx
After i posted the question about synthetic i called the dealer...
they said dot 3 non-synthetic for sure also
Glad you and the dealer agrees..... dont know if they are always right
Thanks for the help
Posted by: bigdog1279
i have been told by sevrall ppl that not to yous synthetic in breaks couse its harder to flush it out and can clog the break lings up that what i have heard just saying what iv been told guy
Posted by: ILL VII
Do not under any circumstances mix synthetic and regular brake fluid.
It has been known that your hoses SWELL UP and can blow.
DO NOT MIX THE TWO
To put synthetic into your sytem you either have to flush AND vacuum the WHOLE system (still wouldnt trust it)
or replace all your rubber lines
just use regular brake fluid, 95% of the vehicles out there use it.
:i
Yes
Posted by: fordtechguru
yep, avoid synthetic, actually, independent studies have confirmed that ford brand dot 3 has better boiling point and performance than some dot4's.. i believe it's like 475 degrees.. as soon as it starts to turn green or brown flush it!! your abs will thank you..
Quote:
