hi,
alright from the beginning,my dad bought this 93 caddy eldorado from the local auction ran good,started right no problems,other than the tranmission was on it's last leg,anyways,he ordered a brand new tranny from cadillac dealer,and we dropped the motor and old tranny out of the bottom of the car,figured we would go ahead and put some new gaskets in it while we were at it,anyways,we finally received the transmission,and connected it back to the engine and reinstalled,turned the key,it fired right up,ran it up the road for a test drive,couldnt have ran better,maybe went 1-2 miles round trip,pulled back in the driveway,the car shuts off,and wouldnt restart,it wasnt getting fuel,it would start with starting fluid,anyways trying to track that down,and think we found it,was a kinked fuel line,fixed that up,tried to restart,still just's turns over,check for spark,nothing,know we dont have spark,we dont have fuel either,"via checking the plug tips"we are stuck,there was two plugs unplugged right infront of the drivers front wheel,they were unplugged when we started this project,cant seem to find where they go either,and also upon further checking found another plug unplugged coming off the main harness under the throttle body,again lost where that would go two,this one is a male plug,with 2 wires,any ideas???any wiring diagrams we can look at?also forgot codes on the cluster reads like this.
I034 - loss of powertrain control module data
T037 - LR wheel speed sensor cotinuity fault
T072 - serial data link fault
T073 - PCM ebtcm/ebcm pulse width modulation signal fault
S044 - lift or dive signal fault
also says
no pcm data
no acp codes
no sir codes
if anyone could give us a hand we would be greatly appreciative,we are lost with this,next source is paying 80 dollars an hour and take it to the local dealership...thanks for your alls time,and sorry for the long thread.
again it's a 93 cadillac eldorado 4.6 northstar v-8 auto tranny. front wheel drive.i think that all you would need.thanks again.
