Originally Posted by GreenJay
Thanks towncarss for the info! Is it difficult/tricky to replace the plastic switch?
Originally Posted by towncarss
no it pretty you simply pull that whole interior light assembly out ( carefully) and remove the sunroof switch from the back ( the part that would be covered by headliner if it was in place) there are 2 options.. you can replace just the plastic rocker switch by just slipping it in place or you can replace the switch from the connector back... but it is about a 2 on a 1-10 scale very easy to do for me |
im in worcester...
i have never gotten just the button itself from ford... which is all that breaks i havegotten the entire assembly with wire and all from ford for about 65 dollars.. HEY WHOS GOING TO THE FALL CRUISE NIGHT WE ARE TRYING TO PLAN??? |
out of luck when it comes to colors.
Originally Posted by 1995towncar
Ok, here it is! Herer are the numbers. The part number for JUST THE PLASTIC TOGGLE BUTTON for the moon roof switch is: F7VZ-13B778-AA. That's the little black button. I talked with the service manager at the dealership. He didn't know the button could be ordered by itself. Thanks to Johnathon at the parts counter for working with me on this. The part number for the switch (which is just the switch, not the housing, lights etc.) is: F7VZ-15B691-BA. Of course this has a button attached. keep spares on hand!
Just the plastic toggle switch for the car is only availbe in black from ford. So you are ![]() ![]() ![]() out of luck when it comes to colors. |
Jelsoft Enterprises Limited.
