Well, my on-again, off-again cooling system problem that I've been troubleshooting for a while has finally come to an end. I've found the problem. My head gaskets are shot. I wish I would have just taken the car to a shop in the first place, because after seeing how simple the test is to check if the head gaskets are shot, I could have avoided all the t/s'ing I've done so far (replacing the thermostat, water pump, temperature sensor; coolant flush, pressure check, burping the coolant system).
Originally Posted by brendangillespie
My question is, before I get this expensive work done, is it worth it? I've been told that if I continue to drive the car, it could have permanent damage done to the engine. The problem is, I've been driving this car for about 3 months now, having this on-again, off-again problem... I don't think the head gaskets are in extremely bad shape, just leaking slightly, because the only time I'm seeing white exhaust smoke is when I start the car after sitting awhile (it also start rough after sitting a while).
Originally Posted by 94m5
How many miles are on the car? If it's still driveable, come to chicago this weekend and Ill swap your head gaskets at the meet. You buy the soda, (and the parts) since it's a dry park. Let me know if you want to do that and Ill bring my tools.
Mike |
Mike |
Originally Posted by buddylee
was you oil milky?? if so the anti-freez can screw up your low end.
Originally Posted by Roadboss
here is a place that offers the whole kit for $130.00.
http://www.karkraft.com/ I would also check with Max at 5 Star. If you are keeping the car stock there's no need to get expensive. |
Jelsoft Enterprises Limited.
