Originally Posted by badbolr
Dude, $100 says it is your rear lamp ballast. I had the same prob last month. It will keep blowing fuses because of a short in the ballast. Dealer wants $800 to repair. Ballast itself is $500 from Ford. Contact this guy. He has a $90 aftermarket replacement part. Cost me $150 to have it installed. You can probably do it yourself. Works fine. Glitch got it to me in a short time.
glitchm@hotmail.com http://www.markviii.org/~glitch/InverterRAI.html |
Originally Posted by MarkVIIIdude
Dude,
Were you having problems with your rear lamp ballast before your fuses started blowing? Cause mine hasn't been working properly since last summer and only bout 4 months ago it just stopped working altogether, would only come on when the lights went on and then went out. If that's it, that'd be awesome and would solve a bunch of probs for me. Is your rear ballast and fuses etc. all working good now? Thanks for the info.. hope it works! |
Jelsoft Enterprises Limited.
