2000 V6. Barely cool on drivers side, warm on passanger. Doesn't matter if I turn the car on and off. No leaks, full of R134a.
Previously I had thought that the divers side was good, but it is not nearly cool enough.
What gives?
Asim
Posted by: Fordman
Does your compressor kick on??? If so your climate control unit may be bad. Because your saying it's blowing cooler on the driverside than the passenger side. Good luck
Posted by: Asim
Guys:
Just spoke to the dealer. Said that he had to add 2 lbs BUT no leak was found. Said that they pressure tested it, added die, etc. and no leak. Added 2 lbs and it is cold. How can their be no leak and I loose 2 lbs. I've seen other posts on here that a few guys have said they too have had to recharge.
Also (tell me if you've heard this before), the guy said when you have it at the lowest temp, it overrides the dual zone and sends all the cold to the driver. Does that sound kosher?
