Originally Posted by mholhut
P1151 Lack Of HO2S-21 Switch (Left pre-cat O2) Indicates Lean. Got an air leak in the intake somewhere? Check all the clamps. Remove your MAF and make sure theres no crud on the sensor wire.
P1131 HO2S 11 (Right pre-cat O2) Indicates Lean. The system is correcting RICH for an overly LEAN condition. The Heated Oxygen Sensor (HO2S) voltage is less than 0.45 volts. This is usually due to a vacuum leak after the MAF. It can also be caused by a bad PCV valve or PCV system hose, or by low fuel pressure or a plugged injector. How do ya like them apples? |
Originally Posted by 1BADLS
Thanks for the info, I started it yesterday, it ideled more like my Big Block Camaro!! I reved it, but all it did was pop-and stutter. Finally, it reved to the 3000 limiter, drove it to work, hammered it, a loud pop and a bunch of black smoke out the pipes, Now it fine??? Maybe the cat was clogged, or intake had some carbo build up??? Who knows, well see if it keeps on running right huh?
Jelsoft Enterprises Limited.
